What to Look for when Choosing the Best Structured Wiring Systems
Structured wiring systems allow for a fully integrated powering of your entire home. Rather than provide unique wiring setups for cable, phone lines, power and other potential needs, a structured wiring system connects all of these wires in one bundle and sends them throughout the house. This allows you a great deal of flexibility in your interior design and the electrical appliances that you install throughout your home for years to come. Because structured wiring systems are a crucial part of how power is supplied to the various parts of your home, it is important that you ensure that you purchase the best structured wiring system available. Read on for some tips on making your selection.
Types of Wire
Category 3 cable is the minimum approved standard for the wire used in structured wiring systems. However, because you'll likely plan on using your wiring for many years to come, it is wise to invest in higher grade wire. Category 5 is typically a good selection for your voice and data systems. An RG6 coaxial cable is useful for video as well. You may also wish to upgrade to fiber optic cables for your structured wiring system. However, this technology is quite a bit more expensive to purchase and install, and the benefits are generally not proportional to the price that you'll pay.
Design
The idea of a structured wiring system is that it will provide all of the various types of power to all parts of your home. If you know for certain that you will not require a particular type of outlet or power line in your home or in a particular part of your house, you can save money on your structured wiring system and on the installation process by specifically selecting a setup that does not contain these lines. However, be aware that this may be a limiting factor later on; if you do decide to add that particular type of wiring later on, the process can be very expensive. Additionally, if you plan on reselling the building that you're wiring, this will potentially serve as a hindrance later on as well.
Shop around for the Best Deals
The cost of the materials necessary for a structured wiring system varies significantly based upon the functions that you desire, the size of your system and home and the grade of wire that you use. It may also vary according to where you purchase it. Additionally, the cost of installing the system will shift dramatically between different places and contractors. before purchasing any wiring system or having it installed, consult with all of the available installers and dealers in your area. By doing this you'll get a sense for the fair cost of the installation and the materials, and you'll be able to shop around for the cheapest system and the best installation package deal.
If you have any other questions about structured wiring systems that may pertain to your home or situation specifically, consult with a contractor or a dealer for additional information. Structured wiring systems are highly customizable to your needs, so it is good to know all of the options that are available to you.
