What Wall Anchor Should I Use for Stucco?
If you need to hang something on a stucco wall, a wall anchor can lower the probability of damaging the stucco. A plastic wall anchor may be best for this application, especially if the item you need to hang is lightweight. Anchors are easy to install, and you should be able to do the job relatively quickly. To install, simply drill a hole into the stucco and then tap the anchor into the wall. Push in a standard screw, and the anchor will be ready to support whatever you need to hang on it.
