Login Error
Close
What Works Best to Remove Scratches in Stainless Steel?
by DoItYourself Staff
Today’s kitchens are full equipped with top equipment like stainless steel, and, while it may look chic, stainless steel scratches easily. Do not let that discourage you though; it is also one of the most durable substances on the market for kitchen appliances. There are ways to keep the stainless steel looking shiny, bright and clean with a little bit of elbow grease.
Many Cleaning Options
Whether it’s using a store bought cleanser specifically for your stainless steel appliance that needs cleaning or a simple soap and water solution, check with the manufacturer first before cleaning.
Simple Solutions
One of the easiest and safest ways to clean stainless steel is with a micro fiber cloth that can be purchased at any home improvement center or house wares stores. A micro fiber is soft and doesn’t not have any harsh fibers that could further scratch the appliance. Simply rub and then buff to clean any stains and, while scratches won’t disappear, they will blend in better once they have been cleaned with the cloth.
Water and Soap
Try using a solution of mild soap detergent and warm water to clean any stainless steel surfaces that have scratches. Mix equal parts of the solution in a bucket of water and then use a soft terry cloth or dish rag to clean the area. Next, buff the area with the micro fiber cloth or another dry, soft towel to shine. Scratches will be less visible. You may have to try these steps a few times before you see any difference in the surface or scratches.
Store Bought Products
Since there are a number of appliances that are manufactured with stainless steel, there are also cleaning products available to use on them. There are numerous solutions, powders and other store bought cleaners that can be administered specifically on stainless steel. You must read the directions carefully and follow each step as intended. Depending on the depth of the scratches, the solution may need to be used more than once and regularly. Store bought products such as stainless steel cleaning agents can be found at most home improvement centers as well as hardware stores.
Hire a Professional
If all else fails and the scratches are too deeply embedded in the surface of the stainless steel, you might have to call on a professional to help remove them. An appliance expert may be able to recommend a specialist that not only cleans but resurfaces stainless steel, as well as a home improvement center. Typically, the person is well trained and uses various methods to remove scratches from the steel, like heavy buffing equipment. Ask for an estimate up front before the job starts to avoid any surprises.
All the suggestions above aside, the majority of stainless steel scratches become unnoticeable after a certain period of time. In fact, they just seem to fade into the overall surface of the appliance. With proper day-to-day care, it is possible to avoid making any scratches in the stainless steel by being careful to begin with.
 forum activity
