Login Error
Close
What's the Difference between Organic vs Inorganic Fertilizers
by DoItYourself Staff
When choosing fertilizers, there is one very important decision you need to make: organic, or inorganic? Both have their perks as well as their drawbacks. While there is no right or wrong fertilizer to use, there are fertilizers that will work better for you and your garden. Below is a list of all of the pros and cons of both organic and inorganic
fertilizers.
Organic Vs Inorganic
Organic fertilizer consists of materials that normally come from the remains or the result of different types of organisms. Microorganisms from the decomposing soil help to fertilize the plants by making its nutrients readily available.
Inorganic fertilizers are sometimes completely, or at least partially, comprised of manmade materials that are used to maintain the growth of the plants. Normally, manufacturers will combine specific kinds as well as amounts of different elements. This is according to the growing condition that is needed, as well as the crop that is provided.
Organic Fertilizers
Organic fertilizer will help decrease the danger of over-fertilization because its nutrients are released very slowly. Organic fertilizer will also help make your soil better. It does this by escalating its ability to hold its water and its nutrients. It also will decrease erosion and soil crusting that is caused by rain and wind. Doing this will add a lot more of the natural nutrients, improving the structure of the soil.
Organic fertilizers are known to leave a bad smell. They are also difficult to handle because they are so messy. Your flowers and plants will stay nutrient deficient until the process of decomposing is finished. This can sometimes take a little while. So for any kind of emergency, you cannot use an organic fertilizer. Because organic fertilizers do not contain much of the three key ingredients, you are going to have to use a lot of it to make sure that your plants are getting the right amount.
Inorganic fertilizers have the necessary amounts of the three main nutrients that your plants require to help them to survive and flourish. They also release quickly so that your plants are able to get the vitamins they need as soon as possible. If there is an emergency and you need to get your plant fertilized as soon as possible, inorganic will be the right choice for you.
Inorganic fertilizers can sometimes leach, which  happens when irrigation washing or rain gets below the plant root level. Nitrogen is very vulnerable to all kinds of leaching. Most kinds of inorganic fertilizer have a high acid concentration, including sulfuric or hydrochloric acid. This will eventually lead to a high soil acidity. This can completely destroy the ability to supply your plants with any kind of nitrogen as well as any kind of nitrogen fixing bacteria.
 forum activity
