Login Error
Close
When removing paint from brick, how do I retain the original color of the bricks?
by DoItYourself Staff
Removing paint from brick is done by using chemicals specifically marketed for that purpose. The best way to remove paint from brick and retain the original brick color is to get a paint removal solution from the experts at your local home improvement store. Apply the solution to a small corner of one of the bricks and allow it to sit as per the chemical manufacturer's instructions. While wearing a pair of safety gloves, use a stiff brush to remove the solution from the small test area of the brick. If the solution removes the paint without damaging the brick, then apply the solution generously to the rest of your bricks.
 forum activity
