cancel
Job type :
Zip Code :
community forums
comments
When To Run Sprinklers
Installing sprinklers provides you with a hands-free, automated method of watering your yard on a regular schedule. However, it's critical to use your sprinkler system in a way that will conserve water while saving you money that would otherwise evaporate into thin air.
Minimize Evaporation
By watering your yard or garden during the peak afternoon sun hours, you can lose up to 70 percent of your water to evaporation. When you turn your sprinkler system on when the sun is high in the sky, evaporation loss is inevitable.
This problem is easily addressed by setting your sprinkling system to turn on during the coldest hours of the day. The hours just before sunrise are the coldest; generally between 2 and 4am.
For maximum efficiency program your system to water your lawn at least 2 hours before sunrise. This schedule ensures that your soil will absorb the most water and that you will suffer the very least amount of water loss through evaporation.
Also, bear in mind that the average lawn needs about 1 inch of water per day to maintain health. To be sure that you are not over watering, leave a pan within range of your sprinkler and then measure the depth of the water after watering.
member comments
Related Articles
How to Set Sprinklers
Learning how to set sprinklers is not a difficult process by any means, but it... read more
Maintain Your Old Sprinklers
Sprinklers are an expensive addition to your home, but well worth the investment... read more
Calibrating Your Sprinklers
When adjusting your sprinkler system for the proper amount of water, know how much water... read more
articles we like
Type 2 Diabetes
Type 2 diabetes commonly affects people between the age of forty and forty five. The... read more
Nominal Size
The nominal size is a term used for lumber that is not dressed, or finished... read more
You Can Still Make Money in the Stock MarketYou Can Still Make Money in the Stock Market
In this economy, you just can't afford to lose money taking guesses with your investments... read more
sponsored articles of the day
diy centers
