Login Error
Close
When to Use Wood Glue
by DoItYourself Staff
Wood glue is a strong adhesive sealant used to hold pieces of wood tightly together. There are many different instances where wood glue can and should be used. There are many different wood glues currently available for different uses. It is important you know about when to use wood glue.
Breaks
Wood glue can be used when you discover a break in one of your wooden fixtures or pieces of furniture. Small amounts of wood glue are very strong and the wood glue will bond any broken pieces of wood back together. Wood glue will solidify, which means you can sand it after it has dried to remove excess blobs and patches. This will help your repair work using wood glue to look more professional.
Securing
A main use for wood glue is for holding. This is when the wood glue will act as a holding agent before you attach large bolts or screws, which will secure pieces of wood together permanently. Wood glue will wear down faster than a strong bolt or screw. You should do this by using large screws to fix the pieces of wood. The screws will take the main weight of the wood while the glue you applied will act as additional support.
Decoration
Wood glue can be used to fix large pieces of wood you are using for decoration. A good example of this will be wooden skirting boards and frames. All you will have to do is run a large amount of wood glue along the back of a wooden skirting board or frame. This will help stick the item to a wall while you secure it more efficiently. Wood glue is the fastest way to add a final decoration to a wooden fixture or piece of furniture. Wood glue can also be used to fix down wooden tiles in a room in a discrete way.
Crafts
Wood glue is a superb material to use in a craft hobby. This is because tiny amounts of wood glue are enough to fix small pieces of wood together. This will allow the creation of large wooden statues or objects, which will not fall apart for a long time. Many of the adhesive glues supplied with craft packs are weak and structurally inefficient. An efficient brand of wood glue will not cost you much and will be efficient. A wood glue will half the amount of time you need to make something. It will also save you a great deal of money from having to buy more low quality glue.
Temperature
Avoid using wood glue in any job or construction project when the weather is extremely hot. Hot weather will weaken the structural integrity of most common use wood glues. This will make them useless and the wood glue will not bond efficiently. The wood glue will dry too quickly and will start showing cracks and damage a very short time after you have applied it in hot conditions. This will be extremely frustrating if you are trying to complete a job quickly. Wood glues, which work in high temperatures are also more expensive and difficult to find.
 forum activity
