Where to Find Split Rail Cedar Fence Logs
If you are thinking about installing a new split rail cedar fence, you will need to find a location where you can purchase materials for your project. Cedar is a fairly popular wood that should ultimately not be too hard to locate. Use the tips below to locate split rail cedar logs for your new fence.
Chain Home Improvement Store
One of the easiest and most effective ways to locate split rail cedar fence logs will be to go to one of the large home improvement stores in your area (Menards, Home Depot, Lowes, etc.). These stores typically have lumber yards attached to them and will usually have a good selection of split rail fence posts. If they do not happen to carry the cedar logs that you are looking for, they would probably be able to point you in the right direction of someone who would.
Independent Lumber Yards
If you would rather not go to a large chain home improvement store, or if it is not convenient for you to do so, you can also try going directly to independent, locally owned lumber yards to find your cedar logs. These smaller operations will often have what you are looking for.
