Login Error
Close
Where to Place a Bathroom Heater Fan
by DoItYourself Staff
On a cold night, a bathroom heater fan can make a tremendous difference when you step out of the shower. Bathroom heaters can come in a wide variety of different styles and can be located around your bathroom. Many people love the way that their bathroom heater fan will create a warm area in their usually cold bathroom. There are several places that the bathroom heater can be installed so that unit can effectively work to keep your space nice and toasty.
Ceiling Mount
One of the most common types of bathroom heater fans is one that is mounted on the ceiling. This device is controlled with a switch and gives off heat that is circulated around the room. Some models also include a bathroom light. The usual placement is in the ceiling just outside the shower area or near the toilet. However, it depends on the size of your bathroom and where you want it to go.
Wall Mount
Another common type of bathroom heater fan is one that is mounted on the wall. This is more of a bathroom heater than anything else, but does give off a great amount of heat. They are usually installed near the door, under a window, or on the same wall that the shower is located. The heat is even and is controlled by a switch on the unit itself. Unlike some bathroom heater fans, you can also set the temperature you would like.
Baseboard Heater Fan
In some bathrooms you might be limited in the amount of space you have. You might also not have the attic space above the bathroom you can use to install the heating fan. In case of this situation you can use a baseboard heater fan. They are a little different from baseboard heaters as they circulate the heat instead of radiating it. They install as a part of the baseboard and can blend into the wall. This type of heating fan is operated manually with digital settings.
Window Heater Fan
Homeowners also have the option of placing a bathroom heater fan in the window. This window heater fan is more of a fan that draws in the heat from the outside. They sit in the window frame and are operated manually with a switch on the unit. They generally circulate the air without any type of settings.
Countertop Bathroom Fan
One final option is to place your bathroom heater fan on your countertop. These portable heater fans will heat up very quickly and blow out the heat from the unit. They can have several options on them such as temperature setting, length of time to run, time to turn on, and automatic shut off in case they get too hot.
Finding a place for your bathroom heater fan is not that big of a problem when you know what type of fan you want to use and the options that they have for installation.
 forum activity
