Where to Place Your Home Theater Subwoofers in Your Entertainment Room
Home theater subwoofers provide a low rumble bass sound that is important as part of a home theater or entertainment system. The placement of your home theater subwoofers in your entertainment room should maximize this effect and produce a sound that compliments the type of entertainment that you desire.
Short Answer: Place the Subwoofers Near the Television Set
The short answer is that the home theater subwoofers should be placed to the right and left of the television set in the home theater. This produces the best sound for your home theater system and will give you the desired affect. Why this is the best placement seems based more on the recommendations on professional installers and others who are more versed on the arrangement of subwoofers and other speakers that make up your home theater entertainment system.
Long Answer: Determine the Best Location of the Subwoofers
The placement of your home theater subwoofer should be based on your sound preference and in a place in your home theater and entertainment room where you can hear the best. This may including mounting the subwoofers above the main speakers in your system or placing them in the corners of the entertainment room. If you have four or more subwoofers you may want to consider placing them as far apart from each other so that they do not cancel themselves out when working in your home theater system.
Factors to Consider
There are factors that must be considered when deciding where to place the subwoofers in your home theater entertainment room. The first consideration is the amount of power that the subwoofer needs to produce the sound and the accessibility of power outlets necessary for the placement. Subwoofers, in relationship to other speakers that make up a home entertainment system, require greater power capacity in order to work. This means that you can conceivable have set up a system that is draining all of your power in order to direct the output necessary to operate your subwoofers at the capacity needed.
Configuration of Entertainment Room
The configuration of the entertainment room where your home theater is located will give you some clues as to where you should consider the placement of the subwoofers. In a room that is rectangular or square in its configuration, you should consider placing the subwoofers on a diagonal in the corners. This will force the sound of the subwoofers to the middle of the room, as in the case of a triangulated signal and produce a clear, coordinated sound.
How to Make a Determination
The best way to determine where the subwoofers should be placed in your entertainment room can be done by simply by trying out different placements of the subwoofers. The different configurations can give you the opportunity to try out sound in different areas of your home and determine where the sound is the best for you.
