Login Error
Close
Where to Start with Bathroom Plumbing Repair
by DoItYourself Staff
Bathroom plumbing repair is something that most people don't consider until it's too late. Many people will just turn on a faucet and expect water to run out of it. However the plumbing systems in your bathroom are actually very complex and deserve a lot of respect. If you ever experience any problems with your plumbing systems then you will find it beneficial to learn about plumbing problems.
Beginners Guide to Plumbing
As a beginner there are some very important things that you will need to consider and learn about. You need to be able to build and maintain a plumbing system which is reliable and trustworthy. If you can construct a reliable bathroom plumbing system then you won't need to think about repairing the systems as often.
Learning about these plumbing systems can make it much easier to complete various projects and repair bathroom plumbing when it does all go wrong.
Fixings
It's important that you have the right fittings and pipes for a variety of different reasons. If you ever replace any pipe work or faucets then you must ensure that you replace it with the same type.
Water Heater
The water heater will be one of the most commonly used pieces of equipment in your bathroom. You must check that the water heater is installed properly and that it's working exactly as it should be. All water heaters have a certain capacity which is the amount of hot water that it can supply. If you often run out of hot water then the reason could be due to using a water heater which is too small.
Modern Materials
Whenever you are doing any bathroom plumbing projects it's important that you use modern materials. Plumbing has changed a lot over the years and you must make sure that you are using the latest techniques. Modern plumbing supplies are more effective, easier to use and often cheaper.
Tightening
Whenever you are fitting new plumbing systems or repairing them then you must ensure that everything is tightly secured. This will make it much less likely for the pipes to spring a leak. Leaks are very dangerous because they can cause damage to your flooring or decor. Even experienced plumbers can easily make the mistake of loosening and forgetting to tighten various fixtures again.
Equipment
Equipment is essential to ensure that the bathroom plumbing projects are successful. You will need some very important pieces of equipment, including:
  • Pipes
  • Fittings
  • Faucets
  • Wrenches
  • PTFE plumbing tape
Plumbing doesn't actually require lots of tools, but you must make sure the tools you have are of the highest quality. You will also need to ensure you're using the right pipes and fittings. Always measure to check the length of the pipes instead of just trying to guess.
It's also worthwhile keeping a stock of different sizes of faucet washer. This means that whenever your tap starts to drip you will have the tools and supplies at your disposal to put it right and sort the problem out.
 forum activity
