Login Error
Close
Why Buy a Solar Roof Fan?
by DoItYourself Staff
Lots of property owners have an interest in good attic ventilation, and many may choose a solar roof fan as an attractive option for lowering the heat in an attic. Excessive attic heat can decrease the efficiency of your cooling system or damage materials you've stored in the attic. Some building codes also call for proper attic ventilation.
The solar roof fan facilitates this ventilation without tying into your home's or building's electrical system. The sustainable component is often installed directly into a roof. The solar roof fan operates through a solar panel, utilizing the power of the sun. Units are generally self-flashing and contain proper shielding from the elements.
Operating Costs
The most obvious benefit of solar-powered ventilating fans is the operating costs. Even though solar power may still seem inadequate for some home power uses, the solar fan demonstrates that in many areas, the natural power of the sun is sufficient to supply power for this localized cooling option.
Electrical System
Another advantage is that professionals can install a solar roof fan without accessing your home's existing electrical system. This fact may be particularly attractive if you have paid out large sums of money to electrical contractors for even the smallest wiring jobs. Some people also argue that having self-contained systems in a space such as an attic can help with certain fire safety issues.
Longevity of Roofing Materials
Some roofing experts also contend that a solar roof fan will help provide longevity for roofing materials. An under-ventilated attic may radiate more heat to the roof. While your roof is designed to take direct sunlight, its lifespan is still related to the amount of heat and light it receives over time.
Issues with Solar Roof Fans
In some areas of the country, a solar roof fan may not be as popular because of concerns about the way storms can affect property. In climates with high winds, the conventional solar roof fan may not be the best option. If you live in such an area, you can ask about getting a gable-installed fan or one that may use remote solar power.
 forum activity
