Why Choose Wood Ceiling Tiles over Tin?
When considering the materials available for your ceiling project, consider wood ceiling tiles in comparison to tin. These are two common types of materials in home and construction projects that have distinct differences that stem from the nature of each material, and it helps to be informed on the properties of each as you try to make choice for your new ceiling.
Wood Ceiling Tiles
Wood ceiling tiles come in a variety of types, including maple, beech and pine, among others. You can also choose from a range of veneers or thinner woods, which are often used as a sheath on the ceiling tile instead of full, solid wood tiles. This is the best choice if you are going for the look of wood without the cost of solid wood tiles. Wood ceiling tiles are offered by some of the best names in the home industry, and among the many reasons owners and contractors choose wood panels due to the warm look and improved acoustics they provide. There are also many sustainable options available.
Tin Ceiling Tiles
Tin ceiling tiles are available in a variety of styles and textures as well. These are generally used by contractors in larger buildings because of they are cost-efficient. Tin and other metal tiles are preferred for these larger projects for their durability, low maintenance, and humidity resistance. They are offered in a variety of colors, styles, and textures. If considering tin, consider perforated options to improve the acoustics of the rooms you are using tin tiles in. Tin is an especially popular metal ceiling tile to use because of the ease at which it takes on patterns and fine detailing. The price of tin tiles would also be comparable to wood veneer tiles, depending on the availability in your area and the customizations you need.
The Winner: Wood
Despite the cost and durability of tin ceiling tiles, for a home, remember that for luxury and warmth, wood ceiling tiles are the better choice to make. Solid wood offers the best in acoustics and durability, at a cost that shouldn't be a bank-breaker.
Still, before purchasing or ordering any ceiling tiles, you should find a showroom in your area to see the choices in person. While shopping online is great, the colors in the images may appear different than in person. You should also take the time to work with a ceiling tile specialist to make sure you choose the right tiles for the purposes and overall look of the rooms you are considering them for. They will be able to help you make the right choice between wood or tin tiles for the best beauty and functionality of your home or commercial property.
