Login Error
Close
Why Foam Attic Insulation Costs More
by DoItYourself Staff
Foam attic insulation costs are more than other types of attic insulation, such as radiant barrier ceiling insulation. The use of foam attic insulation provides a higher energy or r-value than other types of insulation. Much of the cost associated with foam attic insulation has to do with properly installing the material to ensure that it will provide the desired energy savings benefits. It is not as easy an insulation to accomplish as the insulation of fiberglass or radiant barrier ceiling insulation.
The Cost of Foam Attic Insulation
On average, depending on what part of the country you live in, the cost of foam attic insulation (including labor) is $2.00 to $3.50 per square foot. This compares with a cost of $0.50 to $2.25 for materials such as fiberglass insulation and radiant barrier ceiling insulation. These costs are a significant consideration when choosing an insulation material for your attic roof.
Determining the Need for Foam Attic Insulation
If you are able to derive the same energy efficiency and savings from the use of other types of insulation for your attic, you should choose that material for your attic’s insulation. That foam attic insulation may cost more than other forms of insulation should not be the only factor to take into account when considering the importance of reducing the energy that can be lost through your roof.
 forum activity
