Login Error
Close
Why You Need Garage Floor Drains
by DoItYourself Staff
Garage floor drains are the best precaution to avoid a lot of problems. If you don’t have floor drains in your garage it is highly advisable to install some, especially if you live in an area where it holds a lot of rain water. Remember excessive rain water is harmful to buildings; it can seep into cracks and cause a lot of structural problems. Installing new garage floor drains is a very tough job to do, so if you are a beginner, it is probably safer to contact a professional to achieve a proper standard of protection against water.
Excessive Rain Water
The main enemy to garages is excessive rain water. As explained above,  rain water, and water in general, is very harmful for building structures. Garage floor drains are a must if your garage is situated on a slope and on a road that holds a lot of water. After heavy downpours many roads accumulate a lot of rain water, causing the sewage systems to overload. Garage floor drains can help by draining the excessive rain water directly to the sewage system before depositing onto your garage floors.
Areas Where Water Pools
Every garage has pool areas. This is when a garage floor drain comes in handy. Here the water source is not important, but the essential problem is that water is pooling into designated stops in your garage, hence that is where the garage floor drains have to be placed. Remember that pooling water may be harmful, both to the floor and to humans because if it is left there for a long time, it will be an invigorating place for mosquitoes to breed. So as you can see garage floor drains are also very important for your health.
Regulations Regarding Garage Floor Drains
This is very important to mention because some jurisdictions have strict legal sanctions regarding materials and chemicals dumped into the drains. So make sure to check what type of chemicals you can dump into your garage floor drains, especially if they are directly connected to the main sewage pipes.
Cleaning the Garage Floor Drains
Garage floor drains have to be cleaned from time to time to ensure proper functionality, otherwise problems of overflowing water will still persist. Try to avoid chemical solutions as much as possible.
Money Wise
As mentioned earlier installing garage floor drains doesn’t come cheap but if you compare it with the amount you may have to spend in structural problems then it becomes relatively cheap. So if you have water overflow problems don’t wait till the very last minute to install proper garage floor drains.
As you can see there are a lot of advantages for installing garage floor drains. Although as mentioned before it requires a lot of work, in the end it is worth the effort.
 forum activity
