Will a stronger wallpaper adhesive prevent wallpaper seams from curling?
In covering walls with wallpaper glued to walls with wallpaper adhesive, you generally will need to know how to prevent and remedy curling of wallpaper seams. This curling can happens in almost any application of wallpaper installation. You might like to know that wallpaper adhesive strength has little or no effect on this curling phenomenon.
Wallpaper Adhesive Application
Various types of wallpaper will require different types of paste. To keep edges from curling, check with the wallpaper manufacturer about which paste will work better; or, simply use a lightweight vinyl paste. Apply the paste to the walls and wallpaper and allow it to sit until it is sticky before pressing it into place.
