Will a Tankless Water Heater Installation Reduce the Dirty Water Smell?
A tankless water heater installation can provide you with several benefits. For example, it helps to eliminate the dirty water smell that is sometimes common with traditional water heaters. When a unit has a tank, it is possible for bacteria to start forming in the stagnant water. If you remove the tank and instantly heat your water as it is pumped into the house, you can generally avoid the problem of the dirty water smell.
