Login Error
Close
Will Cleaning with Disinfectants Damage Stainless Steel?
by DoItYourself Staff
When you are cleaning stainless steel, you need to see what type of disinfectant you are using. Some disinfectants are fine to use on stainless steel while others could potentially damage the surface. When you purchase a cleaner, you need to make sure that it does not have any chlorine or bleach in the mixture. These substances could potentially damage the stainless steel and etch the surface. Instead of using these, you need to use a milder disinfectant that will not react with the surface of the stainless steel. You may try using vinegar instead.
 forum activity
