cancel
Job type :
Zip Code :
community forums
comments
Window Shutter Hardware Installation Tips
To make windows more appealing from the outside, many homes have installed window shutter hardware. While this is not a difficult process, there are a few things you should keep in mind when installing your shutters.
First off, it can be beneficial to paint the shutters before you install them. This can help since you do not need to cause safety issues by climbing a ladder to paint the shutters and will prevent you from accidentally painting your home.
Next, you will need to secure the hinges to the home. These can be installed by using some sort of mounting device that should be included with your window shutter hardware. Next, while making sure that the shutters are completely level, you can attach the hinges to the edges of the window shutters by screwing them in tightly. It must be stressed that you need to make sure that the shutters are level before you screw them in so that you do not risk putting unnecessary holes in your shutters.
Once you have put the hinge pins into place by inserting them through the top of the hinge, your shutters are completely installed and you can enjoy the new look of your windows.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Decorating For Thanksgiving
sponsored articles of the day
