Login Error
Close
Wired vs Wireless House Alarm Systems
by DoItYourself Staff
For most homeowners, choosing between a wired and a wireless house alarm system can be quite confusing. Both these systems have their share of pros and cons. In the end though, your choice must be based on your personal scenario and the most effective option in your situation.
Ease of Installment
If you choose a wired alarm system, you have to accept the requirement for drilling holes and running wires for installation purposes. This can be time-consuming, which is why it is advisable to choose a wired alarm system if you are in the process of building or renovating your home. Wireless alarm systems are usually installed very quickly, as only 1 or 2 wires are required to connect the main components of the alarm system. Installation charges are usually much cheaper for wireless alarm systems. In fact, installation is so uncomplicated that you can do it yourself.
Cost
Wireless alarm systems cost more than wired alarm systems. Depending on the available features, a wireless alarm system may cost the same or may be cheaper than a wired alarm system when you first buy one. However, you must consider the cost of batteries, which need to be replaced frequently. Some alarm companies also charge a maintenance fee for regular checking of wireless alarm systems. Overall, a wireless alarm system will have you spending much more money in the long run.
Effectiveness
Both wired and wireless alarm systems are efficient. However, wired alarm systems are less prone to accidental alerts. This is because hard-wired alarm systems are much more reliable. Wireless systems, on the other hand are sensitive to radio frequencies, even when they are emitted through passing vehicles. As a result, the risk of false alarms is quite common.
Advantages
One of the advantages of wired alarm systems is that because they run on electricity, they are fully operational at all times. There is no need to worry about a dying battery. You can connect your alarm system in such a manner that in case of emergencies, the police or fire department will be immediately notified. These systems require minimal maintenance once installed. Also, you do not have to worry about finding compatible replacements, which is usually the case with wireless systems when a sensor stops working or a new update is made available.
Wireless alarm systems offer the advantage of uninterrupted operation even in the midst of a power outage. Also, they are aesthetically more appealing and easy to set up in an older home. If you ever move, you can conveniently carry your alarm system along and install it in your new home.
Drawbacks
The only drawback of a wired alarm system is the initial hassle of installation. With wireless alarm systems, reduced reliability is a major concern. Also, many of these systems must be compatible with cellular technology if you want to set up contact with the police or other emergency services. The cost of battery replacements and the requirement for constant monitoring of battery levels are also significant drawbacks.
 forum activity
