Login Error
Close
Wireless Doorbell Installation
by DoItYourself Staff
If you are looking to be able to connect various chimes within your home but you do not have the time to mess with wires, then you may want to look into switching to a wireless doorbell. These systems are typically battery operated so you will not have to worry about plugging anything in at all!
Turn Power Off and Uninstall Old Switch
The very first thing that needs to be done is you need to turn off your power. Some people do keep their power on because the most power that is running through the wires to the doorbell is only about 12 Volts. The power can be shut off through your circuit breaker or fuse book on the side of your home. Once the power is shut off, you then need to take a screwdriver and unscrew the old switch out from the doorframe. This should only take a few light turns and you will be all set to go. Remove the old switch and disconnect the wires from the wall.
Cut or Tape Up Old Wires
Because you will not be using a switch that needs wires, you have no further need for your wires. You can cut them, but it may not be a wise idea due to the fact that you may run into a situation where you will need them later on. Instead, what you should do is utilize some electrical tape and tape of these wires. This way there is no current flowing through them and they will not be in the way.
Installing the Wireless Doorbell
Once you have everything all taped up and out of the way, the hard part is over! You will then be ready to start installing your brand new wireless doorbell. Basically, all you are going to do is place the wireless doorbell over the hole in the door frame. There will typically be a couple of screws that you will need to screw in, and your screwdriver can take care of this job. Make sure that you have placed batteries inside of the doorbell switch before you screw it into the door frame. If the switch has a button that lights up, you will know immediately that everything should be working properly.
Turn Power On and Test New Switch
Once you have everything screwed in and ready to go, all you need to do is turn on your power through the circuit breaker and test out your new wireless doorbell. Have someone stand inside one of the rooms in your home while you stand outside and press the button. If you have multiple chimes running wirelessly through the house, make sure that each and every chime can be heard. When it comes to maintenance for your new doorbell the only thing you are going to need to worry about is replacing the batteries. Take a look into even installing some intercom wireless doorbells so that you do not even have to go to the door to find out who is ringing the bell!
 forum activity
