Login Error
Close
Wiring Guide for Home Alarm Systems
by DoItYourself Staff
Home alarm systems are much more commonplace in today's residential homes. They are installed for security and safety reasons. Most home alarm systems are either hardwired into your electrical system, or they are installed wirelessly with wireless access controls and sensors throughout the home. You can use a home alarm system to alert officials when you have a home invasion, a medical alert or a fire. They are useful and very effective in protecting a household against outside and inside threats. Below are several things you should consider in relation to wiring your home alarm system.
Type of Wiring for Home Alarms
When you are looking to install wiring for your alarm system, consider a 4-wire installation rather than 2. Most home alarm system models utilize 22/4 wiring. This type of wire can be used for all different types of detection and detection devices. It connects to almost every device except a few older smoke alarm devices.
Buying a Kit
There are so many different types of home alarm wiring kits available on the market. A fairly handy homeowner can install the home alarm system themselves. A very basic system that comprises of a bell and a siren can be installed over a weekend. Generally, to install a home alarm system from a kit, all you need to do if find locations to mount the buzzer or alarm, and you need to mount the wireless sensors that detect intrusions. Once you have done this, you can then go to your main circuit panel and attach the circuit to the alarm sounder. Then, you add a battery to the system, and you are all set to go.
Remember to replace the batteries routinely!
Running Wire Appropriately
As you begin to lay out the wiring requirements for your alarm system, you will need to create a separate zone for each component of the system. So, even though you will run everything into a main panel, you need to setup separate components that will give you the ability to determine what the threat is and where it may be. Here are a few different ways to approach zoning:
  1. Setup a different zone for every room in the house.
  2. Setup a different wiring zone for each floor.
  3. Setup a different zone based on the service type (for example: a zone for a burglar system, one for the fire alarm system).
Adding Wireless Keypads
Consider adding a wireless component to you home alarm system. Connect the wireless and remote keypads to the alarm system and run it through to the circuit breaker panel. This gives you a way to activate your home wirelessly and deactivate the settings when you are inside the premises.
Add Remote Monitoring
With many state of the art home alarm systems, you can add remote monitoring capabilities so that when you are out of the home, you can visually monitor and inspect your home's security and safety. You can use a remote monitoring system on any computer that has internet access.
 forum activity
