cancel
Job type :
Zip Code :
community forums
comments
Wood Deck Designs: Things Commonly Overlooked
Wood deck designs will add value to your home and provide you with many hours of outdoor enjoyment. To get the most out of a wood deck, keep in mind these commonly overlooked aspects of wood deck design.
Best Wood for Decks
Pressure-treated woods are often advertised for wood decks. This treated wood will resist rot and insect pests, but is undesirable for the surface of decks due to the presence of pesticides. Instead of using pressure-treated wood for decks, railings and steps, choose a durable wood such as cedar or redwood. Use the pressure-treated wood for framing and supports.
Sealing a Wood Deck Against Weather Damage
When a wood deck is exposed to several seasons of sun and rain, it will begin to turn gray and warp. A sealing treatment will help protect the wood from weather damage. Even a new wood deck should be sealed a few weeks after construction.
Building a Sound Wood Deck
Many wood deck designs require the deck to be attached to an external wall of the house. This aspect of the deck design needs to be considered carefully in order to avoid damaging the house or ending up with an unsafe deck. Consider bringing in an expert to help attach your deck to your house.
One of the best ways to avoid problems with wood deck designs is to learn about building codes. Visit your local building inspection department and find out all you can about details like these that are commonly overlooked.
member comments
Related Articles
Factors to Consider Before Building a Deck
Before you begin building your deck, let this article helps you carefully consider the reasons... read more
How to Build a Deck
Step-by-step instructions on how to build your own deck... read more
How to Plan a Deck
Tips and considerations for planning a deck... read more
articles we like
Support Columns
Support columns are used to help raise floor joists so that floors don't sag. If... read more
Why is Christmas celebrated on December 25?
This article has creative christmas decorations you can make using Christmas tree balls... read more
Free info can help you find government grantsFree info can help you find government grants
Whether you're out of work or just looking for a more stable job, it doesn't... read more
sponsored articles of the day
diy centers
