Wood Laminate Flooring Cleaning Tips
Wood laminate flooring is growing in popularity as a beautiful flooring option. This type of flooring requires prudent cleaning and maintenance. The following are handy tips to follow when cleaning wood laminate floors.
Regular Sweeping
To keep your wood laminate flooring in superb condition, the first things to avoid are scratches from dirt and grit. This type of flooring is worn off easily if grit is allowed to accumulate and walked upon. Keep the floor clean by sweeping it every day with a soft broom.
Avoid Excessive Moisture
Wood laminate floors like all other wooden surfaces do not respond well to excessive moisture. Introducing too much wetness on the laminate will gradually cause the flooring to swell and eventually warp, creating an uneven and unsightly floor. Wood laminate floors do not require to be entirely mopped. Locate areas that are noticeably dirty and spot clean them. Your mop should only be slightly dampened and not dripping wet as with concrete floors. After spot cleaning has been done, you can absorb the extra moisture by drying the spot with a soft towel.
Do Not Use Household Cleaners and Soap
Cleansers and soaps that are regularly used for other floor surfaces must not be used on your wood laminate floor. In the event that you need to use a cleaning agent, purchase a detergent that has been specifically made for laminate flooring.
Under no circumstances should any abrasive cleansers be used on the floor. These will almost immediately deface the finish of the wood laminate.
Be Careful When Vacuuming
Vacuuming is a good way to clean your wood laminate floor since you will be able to collect much more debris and dirt. You should, however, be careful about the type of vacuuming equipment that you select for the task.
Extra care tips for your floor
Heavy ifurniture has the ability to harm your wood laminate floor even when it's stationary. To avoid this from happening, always make sure that these items have felt padding under their feet so that there is no direct contact with the floor. The furniture should not be dragged on the floor but must be lifted entirely when you are moving it.
People should also avoid wearing sharp heels when walking across wood laminate floors for fear of creating nicks and scratches.
