Login Error
Close
Wooden Cladding in the Bathroom
by DoItYourself Staff
A warm atmosphere in a bathroom can be created with wooden cladding on the walls. When properly sealed, wooden cladding can be as easy to clean and maintain as tile.
Decor Styles Enhanced by Wooden Cladding
Soft pine cladding with plenty of knots and grain will add charm to the master bathroom in a country cottage or clapboard house with country decor. A contemporary home could feature a master bath with fine-grained dark walnut or oak cladding, to contrast with clean white fixtures. You can use wooden cladding planks horizontally or vertically on your walls for different texture effects. With careful planning, measuring and cutting, you can attach the planks diagonally, or even create a herringbone pattern in the paneling.
Advantages of Wooden Cladding in the Bathroom
You can attach shelving, mirrors and interior doors more easily on wooden-clad walls than on tile walls. Sealed wooden cladding resists mold and mildew growth that often forms on tile grout. You can sand and paint wooden cladding in the color of your choice with a water-resistant paint to get a non-reflective, subtly textured surface in your bathroom. Wooden cladding can also help insulate the bathroom, as wood absorbs and holds heat better than tile.
Disadvantages of Wooden Cladding for the Bathroom
As wood tends to expand and shrink as it absorbs moisture and then dries, wooden cladding is not suited for use in the tub and shower area of your bathroom. Wall surfaces must be prepared with timber batting to provide a narrow airspace between concrete or drywall and the wood planks.
How to Measure Your Bathroom for Wooden Cladding
Decide whether you will apply the cladding horizontally or vertically. Cladding planks are generally 3 inches wide by 8 feet long. Measure your space to determine how many planks you will need. Most often the planks are sold in packs of 5.
Staining and Painting Wooden Cladding
Allow the wooden cladding to rest in your home for a week before installing so it can warm up and dry out a bit before you hang it. Apply your chosen stain or paint to your wood panels at the end of this acclimatization. If you want to use this wall covering behind your sink or near the shower, seal it with marine varnish before installing.
Applying Wooden Cladding
Affix timber batting to the bathroom walls. These batting planks measure 1 inch deep by 1-1/2 inches wide. Space the batting planks 6 inches apart, using existing wall studs behind drywall to anchor vertical batting. If your bathroom walls are solid plaster or concrete, attach the batting with masonry screws. Start at one edge of the room and connect the wood panels via their tongue and groove edges. Finish with a panel with a tongued edge that can be sawed off just before installing.
Finishing Wooden Cladding
You will need to remove existing baseboards and trim to apply wooden cladding. Upon installing the cladding, you may want to replace your old baseboards with wider trim to balance the strong vertical and horizontal texture of the paneling.
 forum activity
