Login Error
Close
Wooden Curtain Rods vs. Wrought Iron Curtain Rods
by DoItYourself Staff
Wooden curtain rods and wrought iron curtain rods have been used by people from all sides of globe for many generations. Both of these types of curtain rods can be quite fashionable and can help add character into your home. If you are thinking about redecorating your living room or bedroom, you should consider changing your decorative curtain rods and give your room a different look. To help you choose whether you should use wooden or wrought iron rods, here are some of the advantages and disadvantages of these two types of curtain rods.
Wooden Curtain Rods
Wooden curtain rods come in different fashionable designs so you can easily find something that fits right into the overall lay-out and design of your home. If you want to give your home an old world look, you can always rely on wood to give you the right ambiance. Curtain rods that come with decorative carvings and designs will give your home a distinctive Victorian character. Moreover, wooden curtain rods are very easy to install so even if you carpentry skills are not that good, you won’t have much trouble getting the rods in place.
The biodegradable nature of wood makes is one of the most environment friendly materials to use at home. If you care about the environment, you might want to get wooden curtain rods instead of the wrought iron type. Note that wood rot within a shorter span of time compared to wrought iron so they do not stay at the landfill for a long, long time when you dispose of them.
When it comes to disadvantages, wooden curtain rods are less durable compared to wrought iron curtain rods. When exposed to moisture, most types of wood decay fast so if you happen to be in an area where the weather is almost always damp, you may need to replace your curtain rods more often. As it is, you may end up spending more money on your curtain rod.
When subjected to heavy load, wooden rods may slip and break so if you are thinking about hanging some really heavy curtain materials, you might want to opt for wrought iron rods.
Wrought iron curtain rods come in various designs, sizes and shapes. Some of these rods have elaborate designs while others have a minimalist yet distinctive look so whatever your taste may be, you will surely find something that is right for you.
Durability and strength are some of the greatest advantages of wrought iron curtain rods. Most types of wrought iron rods can last for many years and they do not get damaged easily. When it comes to bearing weight, wrought iron rods are very reliable especially when you add braces in the right places.
When it comes to disadvantages, wrought iron can rust when exposed to damp weather and rough conditions. However, you can easily get rid of the rust by sanding away the rust before apply primer and fresh paint coating. When maintained properly, a wrought iron curtain rod can last for a long, long time.
 forum activity
