Login Error
Close
X10 Home Automation System: Pros and Cons
by DoItYourself Staff
The X10 home automation system is a communications language that can help compatible appliances around your house to communicate with each other. The communication is easily developed through already-existing electric wiring. X10 products have been in the market for decades now and are easily affordable. As X10 products are able to communicate with each other over pre-existing wiring, it saves you the cost of new wiring installations. With functions ranging from turning lights "On" or "Off" or making them dim and regulating the cooling of a particular room at a particular time, the X10 system has worked wonders for American homes and continues to do so.
Pros
X10 products can be found in almost 10 million homes around the US. This popular choice over other systems ensures that you can make an easy decision on buying X10 products now as the system has proven to be reliable over decades.
Installation of the system is inexpensive. As no new wiring is required, the only cost is of buying the transmitters and compatible products. The transmitters and products are both easily available and are extremely affordable.
Apart from being easy to install, the X10 automation system is compatible with hundreds of products. This means that the choice presented to you in choosing products that you would like to be automated at your home is huge. You can have products ranging from lights, televisions, computers, laptops, dryers, treadmills, vacuum cleaners, etc.
The X10 automation system is not only compatible with hundreds of products but is able to communicate with hundreds of products at the same home, at the same time. The automation system can be used to control and communicate with up to 256 lights and appliances.
Cons
Although the X10 home automation system is super-reliable and has a lot of advantages over other systems, there are some issues that may arise and you should keep them in mind.
It can take some time for the signals to travel from the transmitters to the appliances. If you have a lot of appliances being controlled at the same time and some appliances even being controlled for similar functions and timings, the operation time further increases. So, if you’re looking for lightning-fast immediate action through the X10 system, don’t.
Appliances that generate noise like vacuum cleaners or other appliances with motors may create problems. When the electrical noise is combined with codes that may be sent simultaneously to various devices, the X10 home automation system can sometimes miss some signals. This might sound like a serious problem but can be taken care of by installing a noise filter device though.
Also, if you’re trying to run the X10 system with appliances across 2 different electrical phases, that is, the transmitter on one phase and the appliances on another, there can be problems again. Though not a serious problem, the missing of some signals to control appliances can be very annoying for some initially. Installing a phase coupler device however, can easily help you solve this problem too.
 forum activity
