Your Complete Water Soluble Fertilizer Guide Your Complete Water Soluble Fertilizer Guide
Water soluble fertilizer is one of the greatest innovations ever made in agriculture. It makes your crops and plants grow healthier, and it is more efficient than the ordinary fertilizer that you often utilize by applying it to the soil. You must always read the manufacturer’s instructions carefully before you use water soluble fertilizer.
There is an entire list of advantages for water soluble fertilizer. It forms no sediment on the soil, and it provides your crops and plants with an abundant source of nitrogen, a chemical that is very important in agricultural cultivation.
1 - Solubility
Water soluble fertilizer gets its name because it has a high solubility, and this enables the user to apply it both to the soil and the leaves of your plants. You can utilize water soluble fertilizer and ordinary soil-applied fertilizer simultaneously.
Fertilizers will not help if your crops and plants are badly cultivated. However, if you apply water soluble fertilizer properly to the leaves of your plants, then you can reduce normal fertilizer usage by twenty percent. Due to its high solubility, water soluble fertilizer can be applied to fruit crops as well (not only vegetable crops), and it leaves no traces when it is time to harvest them.
2 - Usage and Application
You can also apply your water soluble fertilizer through injectors and sprinkles, or you can apply it over your plants by means of an aircraft. You can also choose to utilize it as a dilution or in concentrate form.
3 - Safety
You do not need to worry that your water soluble fertilizer is going to be harmful to particular plant species. However, you must always and never forget to check the instructions provided by the manufacturer, and follow them with attention. Water soluble fertilizer should be compatible to all plants which grow in greenhouses, gardens and nurseries.
Read the manufacturer’s instructions and see if you can use pesticide or fungicide with it. You should be allowed to apply pesticide or fungicide even when you use water soluble fertilizer on your crops. On the other hand, if in the instructions you read that fungicides and pesticides should be used simultaneously with water soluble fertilizer, the reason will probably be because due to its chemical consistency, the fertilizer may chemically neutralize the pesticide or vice versa.
4 – Testing and Analysis
Before it is packed and taken away to be sold, the water soluble fertilizer is tested and analyzed inside a chemical laboratory. Professional scientists and other personnel in the laboratory make sure that each drop of the fertilizer has the same concentration; no part of the chemical should be more intense than the rest. It is also analyzed to check that the water soluble fertilizer does not contain any chlorine-based agents.
5 – pH Stability
Water soluble fertilizer should also maintain a stability on the pH scale, so that it can be applied onto soils that are high and low in acidity. This is very helpful because the chemical formula of the fertilizer itself allows it to dissolve in hardwater as well.
