Login Error
Close
Your Entry Door Repair Guide
by DoItYourself Staff
Entry door repair is a home improvement job many people are afraid to do. In reality, however, this is something that can be done easily, especially if the repair work only requires the removal of scratches or fixing of entryway hinges. Still, many people commit mistakes when doing repairs to their entry door. To help prevent mistakes and make sure that the entry door repair is done carefully, simply read on.
Assess the Problem
Before you start hammering away at your entry door, you first need to assess the problem. Are you dealing with scratches? If so, you need wood filler and varnish to eliminate the unwanted marks. Is the doorknob jammed? Well, try spraying some lubricant or anti-corrosion solution. Assessing the defects or damages to your door is always the first step.
Mind the Material
The material and model of your door parts and supplies play an important role in ensuring that your door functions properly. So, before you buy any type of door materials to use for repairs, it is important that you know your door size as well as the composition of the materials you want to use.
 forum activity
