Your Grout Color Guide
Grout color can make a big difference in the appearance of your tile floor or wall. Consider the following when choosing grout color.
Variety
Since grout is simply a mix of water, cement and sand, any color dye can be added to it. You should be able to find a grout color that complements any type of tile. Keep in mind, however, that the final color may be slightly different than the one advertised. It’s best to test a small patch and allow it to dry before you apply it to the entire floor or wall.
Mixing Colors
If you need to mix colors to get the shade you want, make sure you create enough to cover the entire area. It’s very hard to match a color once it’s been mixed and has dried. In this case, you're better off mixing too much.
How to Pick the Color
For a dramatic look, choose a darker color grout to compliment a lighter color tile. If the tile features a splash of color that you life, you can draw it out by using a grout that complements it. For a classic, neutral look, choose grout in a light color.
