cancel
Job type :
Zip Code :
community forums
comments
Your Shower and Bath Faucet: Time to Replace?
Your shower and bath faucets are often taken for granted. However, there are times when the faucets need to be replaced.
How Is the Water Flow?
Buildup from minerals found in water can decrease your water flow. The problems can be caused by calcium, lime, or other chemicals from treatment plants. These deposits can clog up your faucet and cause the water flow to be low or intermittent.
Are There Any Leaks?
Check around the shower and bath faucets for any signs of leaks. Is there discoloration along the tub or shower enclosure? Are there any signs on the floor? If your tub has a rear access panel, use a flashlight to check for any signs of water around the faucet.
Are There Any Cracks or Breaks?
Are things starting to break off from your faucet? Are the compression rings cracking? Is the valve sending water between the shower and tub? Can you see any visible signs of cracks on the faucet? Replacing your shower and bath faucet at the first signs of cracks or breakage will help save you money later.
Are You Remodeling?
If you are going to remodel your bathroom, consider replacing your shower and bath faucet.
member comments
Did-it-myself Projects
updated by nursepammi
did this on 10/10/2009
Apt. 2 Bath Redo
updated by candbp
did this on 9/11/2009
Project House 2
updated by SMBiker
did this on 5/26/2009
Green Bathroom Demo
Painting Stylish Wall Borders
sponsored articles of the day
