Solar water heater copper to cpvc
Post Your Project
by: Lpenia on 05/02/2014 Views 3938
Budget
$300.00
Tools & Materials
  • None
Summary
I used CPVC yellow cement to glue the copper header with cpvc half inch coupling and pipes on the water heater frame all connections fit perfectly and work with no leaks on an open end circuit free discharge to a pool but for a closed circuit like connecting into a home heater tank the water will steam with solar temperature and increase pressure in the system a relief valve will help but not sure if glue on copper cpvc joints will resist Q what type of glue or epoxy material can I use to reinforce glued joints
Project Journal
  • Please Wait...
Category:
Tags:
  • This project has not been tagged.
Flag as inappropriate
You May Also Like
You are about to send warning of this page to an Editor. Continue?
