Central A/c unit not blowing cold.
My Goodman A/C unit isn't blowing cold. Fan is running but on my inspection the cooling unit is not running. Any suggestions on what to look for?
Matt Anaya:
You first should check the breaker.
Sometimes a breaker can trip but the handles won't move enough to be seen.
Shut the unit off at the thermostat and then turn the breaker off then on.
After ensuring the breaker is on you can have someone stand next to the outdoor unit and then turn the ac on at the thermostat. If he/she hears a click then you know the thermostat is engaging the outdoor unit's contactor and the problem is outside.
Any more than this would require you to check the electrical components with a tester.
