Yes it's the AC again .... leaking water
Old 06-13-04, 10:33 AM
soFlnewcomer
Question Yes it's the AC again .... leaking water
Ok am a novice to all this so bear with me . My ac unit ( I think it's a spilt system ) is leaking water. It has 2 parts one outside and one in an inside closet. Where a pipe connects to the unit on the inside is leaking water. Which starts to flow when the unit is turned off HELP !!!!!
Old 06-13-04, 10:52 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Check and see that the drain line from the inside unit there is clean and open. Blow or suck on it with a shop vac. Is the air filter in the unit clean ? Any ice or frost on the copper lines there by the inside coil. Try this and get back to us .
ED
Old 06-13-04, 11:42 AM
hvac4u's Avatar
probably a clogged drain, happens a lot in florida. after cleaning pour bleach in there from time to time
Old 06-13-04, 03:43 PM
soFlnewcomer
seems to be the Drain
I am checking the drain seems to be where the problem is . I had called a friend who suggested blowing out the drain and using bleach also. Thanks folk will let you know the outcome
Old 06-13-04, 05:12 PM
soFlnewcomer
Thumbs up Alls well in Ac land
Ok poured bleach in there water is now flowing where it should. Thanks all
Old 07-29-08, 01:52 AM
K
My split ac is also leaking water inside the room
Hello,
My ac is leaking water into the room on the second day of usage.
It id not show this on the first day but the problem started on the next day.Please help. What could go wrong. It also drains water on the outside as usual. Thanks
