leak in ac unit
HI guys,
when the airconditioner is working,the inside ac unit starts leaking water .what do you guys think ?
thanks in advance for the feedback.
You dont say just what you have there. Drain line clean ?? dirty filter, coil has dirt in it. Low freon. Blow and suck the drain line first with a shop vac. Big copper line cold and wet little line warm?? no frost on the lines or coil??. you can have a hole in the drain pan ???
Info info helps .
ED
Info info helps .
ED
