Central AC/Heat, Blower Doesn't work on Auto
Old 11-30-04, 06:00 PM
Repete14u
I have an all Electric central AC/Heat system. The problem is on the heat side. The Blower doesn't kick in when the thermostat is in the auto position. AC side works fine and the heat side works when fan is "ON". Help!
Thanks
Old 11-30-04, 06:08 PM
bigjohn1
Can I assume it worked ok in the past? Have you put in a different thermostat? Otherwise, it's probably a bad/malfunctioning sequencer.
Old 12-01-04, 05:19 AM
Repete14u
Thermostat has been replaced. what, where is the sequencer? I read a few threads last night, is there a tiered relay inside the blower that I should be looking at too?
Thanks
Old 12-01-04, 07:59 AM
Ed Imeduc's Avatar
Wink
Check and see if you dont have a wire schematic there on the door of the unit. It should show you where and how the blower relay works for heat. Me too why the new tstat?
Did it work when you put the tstat on? have all the right jumpers on in the tstat?
ED
Old 12-01-04, 11:28 AM
Repete14u
The system was put in a couple months back, dummy me never turned on the heat to see until I needed it. Guy came back out, swapped the ts-stat, relay and heat strip for a quick fix but got stumpped when it still didn't work. going there tonight to see if I can check the wiring to the tstat. sounds like the t-tat wiring may be the best option. I have the diagram, so wish me luck. I'll let me know, maybe easy huh.
Thanks
Old 12-01-04, 11:32 AM
Ed Imeduc's Avatar
Wink
If this was just put in Call them back to fix it for sure.
ED
Old 12-12-04, 02:07 PM
scottg's Avatar
Location: Wilmington, NC hurricane magnet of the U.S.A.
Talking
Digital thermostats now days can be configured to have the fan come on in the heat mode with the call or use a fan limit relay in the furnace. Check to see if the thermostat is configured properly.
Old 12-19-04, 12:42 AM
leeroyborwn
Repete14u?
Repete14u
I am having the same problem. I tried replace T-Stat. without any luck. Did you get yours to work? Any other ideas?
Old 12-19-04, 03:10 PM
Ed Imeduc's Avatar
Wink
Its not the tstat its down in the fan relay or how its wired . You have a year on the unit call them back.
ED
