Need help with central air/heat system
Could use some advice... Have central air/forced hot air. It is in the heat position.
When wall switch is on auto and thermostat is calling, the flame kicks on but the fan only makes humming noise. When switched to the on position- fan works properly. Thanks
Check the blower motor for low speed it can be out. Also the fan relay or control for fan on with heat. look at the wire schematic for the control that turns the fan on on heat
ED
ED
