AC Outdoor Unit Fan won't start
When I switch on the AC from the thermostat switch, the outdoor unit fan does not start. However I hear the humming noice in the outdoor unit (probably of the compressor). As a result there is no cold air coming into the house. However if I push start the fan manually, then is starts rotating normally and the cooling effect is normal. Why is that each time I have to push start the outdoor unit fan? I have not used the AC for about 4 winter months. I noticed this problem when I started using the unit again this summer.
deby
Based on the fact the fan will start when you turn it by hand, I would say there is a strong probability the capacitor is bad. It is a simple repair if you want to do it.
Received 0 Votes
Sounds like it's the capacitor, turn on the unit as you would normally, if the fans doesn't start up try spinning the fan by hand (BE VERY CAREFUL IN CASE THE FANS BEGINS TO RUN), if the fan starts up then it's a very good chance it's the capacitor that went bad..
you can also check the capacitor with an ohms meter to see if it's indeed a bad capacitor..
Just pull the disconnect from the wall, remove the service cover from the unit and it should be in there. It will look like a small tin can with a few wires attached to it. Before touching it you will want to short its terminals together with an insulated screwdriver to discharge it.
** Make sure you've pulled the disconnect out before working in the electrical area.**
Run cap
The one you bought would be for the fan motor. Make sure the power going to the unit is dead, replace the capacitor, & give it a try. Post back with results.
