Central Air Goes off and on
Old 08-28-05, 07:43 PM
1stHome
Hi. Could really use some help. My central air conditioner turns off after less 5 minutes of operation. Goes on then goes off again. Over and over again. I replaced the furnace filter. Any suggestions would be greatly appreciated. Thanks!
Old 08-28-05, 07:49 PM
northbender
no a/c
#1. does the indoor fan run on a call for cooling?
#2. does the outdoor fan run on a call for cooling?
#3. does the thermostat have cold air blowing on it when the cooling comes on?
Old 08-28-05, 07:55 PM
1stHome
Hi Northbender-
#1 Yes
#2 Yes
#3 Sometimes. On occasion we run the ceiling fan with air.
Thank you for your help.
Old 08-29-05, 04:14 AM
mattison's Avatar
If this is a new problem and everything is clean it may be a good idea to have a pro check it out. The refrigerant side may have started leaking and the unit may be tripping on low side safety.
