Central air won't turn on
Old 04-14-06, 09:30 AM
D
And the fan won't go on when I turn it on manually. But if I turn the heat on with the fan in auto, the heat and fan turn on and run fine.
I checked the breaker in the basement, it is ok, and there is some kind of fuse box outside, which looks ok. I don't see anywhere to reset anything outside. It is a Trane 1000xp I think.
Any ideas of simple things to try? I really don't have the tools or background to do anything major. It seems odd that nothing happens at all. Maybe try a new thermostat? I could probably handle that.
Old 04-14-06, 12:30 PM
L
no fan
may be fan relay for heat and cool mode.it may be sticking.is this electric or gas heater.
Old 04-14-06, 01:04 PM
H
If your fan comes on only on auto it might be that your T-stat is bad, I take it that if you put the fan on the on position it won't come one?
Old 04-15-06, 08:32 AM
D
2 things
yes, I turn the fan ON, and it does not come on. But it runs in auto with the heater. It is a gas furnace. I just had the thermostat replaced a year or two ago.
Old 04-15-06, 11:31 AM
Ed Imeduc's Avatar
Wink
AT the tstat jump R to Y outdoor unit should come on.Jump R to G the blower should come on. if they come on for you them its the tstat. If they dont then its on down to fan relay and out door unit.
ED
