Ruud 10 seer iced up
Hello,
I just returned home from vacation to a hot home and 3 inches of ice on the outside of my central air compressor and outside coils. The fan was running on my unit w/out cool air out of the vents. I have flipped the breaker off to let this situation defrost until tomorrow. What do you think? Freon leak, dirty coils, etc.? What should I do next?
Thanks,
Joey
Thanks,
Joey
Ruud 10 seer ice
Hello,
Ice just on the compressor and lines going into the house. Also, this morning the ice has melted and I noticed that the filter/coils(?) next to the compressor is filthy/clogged with dirt, etc. What is the best way to clean this?
Thanks,
Joey
Thanks,
Joey
Received 1 Upvote
1 Post
Out side unit. Turn power off to it and just use a water hose on it to clean it. "Ice on lines." Is inside coil clean ?? blower wheel clean.? Air filter clean. If so next is low on freon.
ED
ED
Received 1 Upvote
1 Post
Where is the blower wheel?
ED
Thanks Ed
I cleaned everything within my capacity. As soon as I turn the unit on there is a small layer of ice which forms on the lines from the compressor to my home, and also on the compressor itself. Also, there is no air blowing into my home.
Joey
Joey
