a/c not cooling my house
Old 05-31-06, 08:23 AM
chris vurch
Hi I'm new to this forum so please bare with me.Here is my question.I have an 11yr old ruud achiever 10 seer 4 ton split system. when I turn the unit on it makes a whistle noise as if you removed the schrader valve from your tire.I don't have r22 guages so i can't get readings but doues this sound like an internal valve on the compressor sticking(p.s lots of auto a/c but not home) auto compressor either work or don't not sure about resid. units (thanks)
Old 05-31-06, 09:02 AM
mattison's Avatar
Could be the internal relief or fan bearings. If you ruled out bearings then you need to call a tech.
Old 05-31-06, 10:31 AM
chris vurch
Thanks; internal relief valve,does that mean a new compressor?
Old 06-01-06, 05:01 AM
mattison's Avatar
Could just be a really clogged coil. Get a tech in there to diagnose it.
Old 06-01-06, 07:35 AM
chris vurch
Thank you, tech coming out mon 6/5 i'll post what they find
Old 06-22-06, 05:19 AM
chris vurch
up date
just an up date, had to replace evap/coil in air handler. Had a hard time finding a 10 seer so had to go with a 13 and retrofit. Seems to be ok. outside temp 82, 63 at register. The temp in my house went down about 6 degr.in 71/2 hrs.does that sound o.k?.I'm not sure.Thanks for the help.
