Are todays window/wall a/c units designed to hold water in pan?
A neighbor just bought a new 10,000 btu window unit. Nice digital with remote, even. Anyway, I told him he didn't tilt the unit and the water was filling up the aprox. 1 inch deep pan. (He then went and tilted it the required 5 degrees.) Then he read his manual some more and it said under no circumstances to drill a drain hole in the bottom to let the water out, as you could hit something. But it gave no other reason. MY window unit has a hole in the bottom to let out the water.
Could it be that the engineers determined that water sitting inside is good?... and cold 50 degree or colder water blowing around in there up against the condensor coil perhaps will help cool the condensor coil better than just air alone?
Don't know if this helps but heres what it says in my manual.
TROUBLE SHOOTING: Water drips indoors: The air conditioner is not tilted to the outside: For proper water disposal,Make sure the air conditioner slants slightly from the case front to the rear.
Normal Operating sounds: You may hear a pinging noise caused by water being picked up and thrown against the condenser on rainy days or when the humidity is high. This design feature helps remove moisture and improve effciency.
Water may collect in the base pan during high humidy or on rainy days.The water may overflow and drip from the outdoor side of the unit.
TROUBLE SHOOTING : Water collects in base of pan---Moisture is removed from the indoor air and drains into the rear of the cabinet where a fan blows it against the outdoor condenser coil:--- This is normal for a short period in areas with little humidty; normal for a longer period in very humid areas.
Don't know if thats helps and thats what it says in my manual for a kenmore window-type air-conditioner.
Your last paragraph does indeed make it sound like the water being blown by the fan, against the condensor coils, is a good thing. So that explains why they only put those notches in the rear of the case not all the way to the bottom of the case, to let out excess water. They must indeed want at least some of the water to stay in the pan.
I'm sure many of those reading this thread will learn something here.
Y'all are exactly right. Newer window a/c units are designed to "sling" water from the drain pan up onto the condenser coils to increase efficiency. This concept started several years ago. If only we could figure out a way to do it with a central unit.
Doug M.
Doug M.
