Condensation Drainage
Old 06-23-06, 01:29 PM
howardlr
I have noticed the amount of condensation running out my A/C drain tube to be quite a lot. It is actually puddling up outside the house and making a "nice" little stream. How much condensation should I see? I live in central Mississippi and it is hot and humid (well, duh...). I am sure this plays a large roll in the condensation, I just didn't expect to see so much.
Thanks ahead of time for all your responses.
Howard
Old 06-23-06, 02:16 PM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Wink
You dont say if new home are what. But with a new home the AC will pull more water out of it. Also if you just turned the AC on the unit might take 5 to 6 days work to pull the water out of the home. After this time the water flow will cut down . The main job of an AC is to get the humidity down in the home. This is what makes you feel cool.
ED
Old 06-23-06, 03:18 PM
Former Member's Avatar
a good flow of condensate water is usually a sign of a well operating system congragulations
