leaking celing
leaking celing
help!!!!!!!!! i have a family room that has 3 celing vents. the last 3days we have had 100 degree weather and our temp is set at 69 degrees. today the celing started to leak by one of the two ball lights that shine on the fire place. how can i stop the ducts from sweating? i have raised the temp in the home to 73 degrees already. i am thinking of a long term repair. i may have to paint celing. won't know till it dry's.
Received 1 Upvote
1 Post
You dont say Is the AC blower unit near there? filter clean? big copper line cold and wet small copper line warm to hot by the outdoor unit? Over flow pan ok drain water running out ok . Metal duct ,flex pipe and ductboard, attic have enough vents to outside. Need lots more info info info To help stay in same post
ED
ED
