One system or two
One system or two
My house is a saltbox with two sections, the main house (34X28) and a attached garage with two stories(22X20) above. The roof lines cross but not the attic space. If I want to install central air do I need two systems or is there a way for one system to feed both sides?
Most of the time when you have more than one story it's best to use 2 seperate units anyway. If the contractor/hvac designer knows what they are doing a single unit can be properly balaced to do the job. But with two systems it's easier to control the seperate floors and if by chance one goes out you will have another area to get relief untill the other is repaired.
Whether or not you can get ducting between the two structures is hard to tell without seeing it. You would benefit from getting at least 3 quotes and make sure they each do a heat load/loss calculation on your home to properly size the systems
Received 1 Upvote
1 Post
Id say go with just one for that sq ft. Just make sure the hvac guy that does the duct work knows what he is doing. So it works right for you. Get 3 bids for this job and make sure they run a heat loss and AC load on the home.
ED
ED
