Air Conditioning Manifold
Is there any difference in a R-12, R-22, and R134a Air conditioning manifold and gauge besides the connectors?...Can one manifold be used with these three refrigerants with the appropriate adaptors?
You have different oils between 22-12 and 134.
If they get mixed you will damage the compressor seals
If they get mixed you will damage the compressor seals.
Also the pressures are different betwen them.
I just located this pdf...can you explain how this manifold can be used with all three refrigerants?
http://www.yellowjacket.com/PDF/P-15.pdf#search=%22YELLOW%20JACKET%20manifold%2041846%22
Received 1 Upvote
1 Post
Dont know what you have there. But in my books manifolds Gauges R12 R22 R502
and R134a R507 R404A another R22 R410a R404a
In yellow jacket. Same thing in the Imperial.
like said make D** sure you blow clean the hose
when you go to another freon
ED
ED
