Air handler problem
Old 05-08-07, 06:42 AM
B
Air handler problem
Hi!
I have a Carrier FA4 series air handler. Yesterday, Noticed that cold air was not circulating. Apparently, the outside unit is working fine but the blower is not turning. The blower won't kick in when t-stat is turned to on, cool, or heat. Tried jumping R to G, but still no blower. Appreciate any suggestions? Thanks.
Old 05-08-07, 08:51 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Check first and see if you hear the blower relay click when you put the tstat to fan on???? With fan on see if you can spin the blower wheel and it runs if so can just be the capacitor. If not on too the motor. Dont run out door unit with out inside fan.
Old 05-08-07, 10:52 AM
B
Unhappy
Thanks for the quick reply...
nope... no click when I turn t-stat to on. I tried turning blower with stat to on and the fan turns freely but wont turn on its own. What do I do next? How do I check the relay and capacitor, or the motor?
Old 05-08-07, 01:10 PM
H
Feel the motor, is it hot to the touch? If yes, then it is probably getting power to it and the problem is the cap or the motor. If it's cold, then it's not getting power which would be a relay, circuit board problem. From here you'll need a test meter to check out the circiuts.
Old 05-08-07, 02:15 PM
B
Unhappy
Well, the motor feels cold. How do I check the relay? Can I by-pass the relay and run power directly to the motor to see if it will run?
thanks...
Old 05-08-07, 04:46 PM
Jarredsdad's Avatar
Can you get the reat of the model number?
And the serial number?
That'll help in getting the parts list and wiring diagram for the unit.
In the short term if you don't hear a fan relay click to start the fan, that's maybe your $20 fix.
Chris
Old 05-08-07, 08:44 PM
B
Unhappy
The model # is FA4BNC048
The motor runs fine when I by-passed the circuit board. What else do I need to check?
Old 05-09-07, 03:38 PM
Jarredsdad's Avatar
Your done
Your fan is started and stoped by a relay on the circuit board. The fact that the fan doesn't work in normal mode but does in whatever way you bypassed it means you need a circuit board.
Look at the board and see if you see any brown or black spots where it may have fried.
You can either get a new board, at what ever price (I maybe able to look that up - next post) or leave the fan on all the time and pay nothing.
Chris
Old 05-09-07, 03:43 PM
Jarredsdad's Avatar
No price
But this should be the part number : HK61EA006
DESCRIPTION BOARD CIRCUIT W/TDR
Hope that helps.
Chris
Old 05-14-07, 05:40 PM
B
Thumbs up
I got the control board I ordered online. I put it in and things are back to normal. Thanks for all the help!
Old 05-15-07, 05:17 PM
Jarredsdad's Avatar
Not a problem
That's why we come here. To help people like you fix the problem yourself and save loads of money.
Chris
Old 06-19-08, 09:49 PM
A
So my motor is hot...how do I tell if it will be the cap or the motor.....fan rotates freely by hand. I can hear the power trying to start it up and the constant HUMMMM but the fan is not turning.
Old 06-21-08, 10:18 AM
HVAC Mech.'s Avatar
The capacitor is always cheaper than a motor, so just replace that first. Make sure all the wires are hooked up and connectors aren't fried.
Tom
Old 07-09-08, 07:51 AM
Hi bokdav1d,
I have the exact same problem. How did you bypass the control board to check if the motor is working fine? If so, I want to order the board online, but in the meantime I need a cool house, I am burning in Arizona, please help, thanks...
Old 07-19-09, 09:55 AM
F
CARRIER Air Conditioner FA4BNC048
Hi expert Community~
I too have a FA4 series AirConditioners (2 units operating separately and independant of each other. One unit cools all the bedrooms and the other unit cools Family and Living and general areas. I have a unique issue: Sometimes one A/C trips and starts cooling when T/Stat is lowered to below the indicated house temp; and the other does not trip. I live in Florida so it is hot around this time of year. When I say it does not trip the I HEAR NOTHING TURNING ON, whether on Auto or on ON position (cooling or heating). We have to use fans to push colder air from rooms to living area or vice-versa depending on which one is working. I went out to the Units in the garage and noticed one unit's copper pipe warm to mildly hot to touch and the other unit copper pipe sort of cold to touch. The Air Handlers outside the house in open sometimes has ICE formation on one of the pipe leading to the fan unit.
Can anyone diagnose and help me with series of checks I can perform and find out how to make them work both whenever I turn them on?
Many thanks.
fjk031
Old 07-19-09, 01:07 PM
D
The one with the ice is the one not working inside? if yes, is the fan in that unit running?
Old 08-17-10, 02:55 PM
air handler
my air handler isn't working right my condenser is running but the fan in my air handler isnt spinning or pushing air through i tried turning off then back on also tried testing my wires at thermostat power is there dont know about the return tho any help please its 95* in my house
Old 12-12-10, 01:02 PM
W
Problem with the HK61EA006 circuit board
I have had the same problem mentioned in this thread ealier four different times over the last 2 years where the outside unit runs but the inside unit fan will not blow or wont go off. Each of the previous three times it has been the control board HK61EA006. The fan is running now and will not go off and I am assuming it is that board again. Does anyone have any idea why this board would continue to go out like this? Can the thermostat cause this kine of issue?
