Thermostat Wiring Problem
I have a Heil furnace Model# NTC5100B JC1, and I diagnosed it to have a bad fan relay board. I picked up a board with the same number on it at My local HVAC supplier. I put the wires back where they come off, but I can't get it to stay running. Any thoughts or ideas will be appreciated. Bill
Received 1 Upvote
1 Post
If you go to fan on does it run for you??? If not . If you jump R to G does it run for you?? If not you have a new board and relay so that should be good. Check the motor and its capacitor next.
Thanks Ed for the advice. The reason I diagonised the fan board bad, was I had no 24v going to condenser. I run jumper between R and G, ran 5 minutes or so and motor quit turning and stopped and makes a noise as it is still electrified.
The same results when I turn it to on.
Do You know if it is a start capacitor or a run? I have been having to give the motor a slight push to get it to run. Thanks, Bill
I found a Nice Gentleman at His Home, He went out to His toolbox and lifted the lid and laid His hand on one the 1st thing. I Thank All for the Help, it is HOT this time of year in Arkansas. Have a Great 4th, Bill
