heat pump or AC
heat pump or AC
i have the choice between a heatpump or AC...the Lennox XC16 AC unit or the Lennox XP16 Heat Pump. After rebates from the power company the Heat Pump ends up being cheaper... Are there any reasons to NOT get a heat pump?
Thanks
Thanks
Received 1 Upvote
1 Post
You dont say what you have there for heat now?? Is this a new unit ,an add on a furnace?? Need more info for sure. What kind of heat will you have with out the heat pump?. All we sell and install around here are heatpumps. Might go to http://warmair.net and compare fuel cost for where you live.
Id go for the heatpump for sure for lesss $$$ even if you just use the AC in it
I live in the denver area...and have a gas furnace that is less than 1 yr old. And according to http://www.met.utah.edu/jhorel/html/wx/climate/maxtemp.html the normal daily temp ea month is above 40 degrees.
